ADP 8242 Not loading enough water or dodgy thermostat
Home Forums Public Support Forums Help And Support Dishwasher Help Forum ADP 8242 Not loading enough water or dodgy thermostat
  • #25325
    trukkie
    back so soon 😆
    Problem:
    Noticed a funny smell at the end of a cycle and the dishes weren’t clean
    so resetarted with the same load in.
    Rinse went as per usual and then started the wash cycle.
    A few minutes into the wash I opened the door to have a look
    I found the water level just below the heating element and since I’d stopped the water from pouring onto it it was very hot (red in parts) and hissing as water splashed on it.
    I’m not sure whether that level is correct or not – there doesn’t appear to be much more room in the tray before it would be coming up to the rubbers so maybe the level is ok and the heating element does not get covered?
    Perhaps the probelm is the thermostat ?
    Any comments would be greatly appreciated thanks
    #205424
    Re: ADP 8242 Not loading enough water or dodgy thermostat
    Below the heater is a typical water level. Water showering down from the rotors is supposed to take the heat off the element. No circulation = red hot heater………
    Cancel programme, set to the soak programme (cold water only), wait for filling to stop and open the door. Hopefully, you should see plenty of water from the rotors. Have a towel handy – you’ll probably get wet 😀 .
    trukkie
    Thanks again P45
    I took all the dishes out did a reset (just in case) and put it on a
    wash empty
    1 hr in and all looks fine
