ADP 8322 (8545 000 15810) Burning smell then fuse blown
Home Forums Public Support Forums Help And Support Dishwasher Help Forum ADP 8322 (8545 000 15810) Burning smell then fuse blown
  • #79116
    willg83
    I’ve taken it apart and removed the heating element. The connector was melted into the socket and the wiring is burnt in places as you can see from the images:
    I want to order replacement parts, but before I do that I just wanted to check is this likely to be a heating element fault or a thermostat problem causing the heating element to overheat?
    Thanks,
    -Will
    #408009
    repman
    Re: ADP 8322 (8545 000 15810) Burning smell then fuse blown
    New heater required plus new connectors (insulated)
    A common problem caused by vibration/poor connection
    Jim
