Thks Tuba and Steve for replying. Just to update and help anyone…it turned into a drama!…I replaced the pump but the sieve filter still seemed to allow the water pipes to pop out slightly..I got 2 replacements but both seemed poorly manufactured as the wash blade would not fit tightly. I then got the old one and glued some small bits of plastic to act as a brace. It all worked until the water pressure switch packed up so replaced that and all good! The machine keeps going :)…
Btw ohms on the original pump showed it was still good. I also had to replace the drain hose as it cracked due to age! but wasn’t blocked.
Thks
Smithie
