Re: ADP 8332
the lugs on the cover sieve usually break stopping the upper feed pipe from clipping back in. also check the seals at the point where the upper basket plugs into that feed pipe, this should be a tight fit, the rubbery seals break down and pressure is lost. you can only get that clip on seal section complete with feed pipe. not a cheap part and usually end up chucking the pipe. customer won’t be very happy after paying for a wash pump job.
