adp 8902 problems
Viewing 15 posts - 16 through 30 (of 30 total)
  • #249970
    Re: adp 8902 problems
    Well the fifth light should be solid but I just noticed you say it’s flashing, is it?
    If it is then it’s actually an unrecognised code in which case it is possibly the PCB that’s goosed.
    karv
    hole with flap is inside the sump ie open door look down
    many diffrent codes means u in test programme or u got low insulation and its screwing ya module up new module will only cure this for short time u need to a insulation check on machine first modules are costly.
    at a guess
    option 1 test programme
    option 2 faulty module
    option 3 had slow leak that got worst as o rings got worst untill u noticed . motor got damp u now have low insulation that screwing up ya module
    #249972
    veloce
    kwatt wrote:That’s because we get asked about it loads of times. 😉
    This should help I hope
    i can imagine. i removed the side fill it was leaking by o rings cleaned out with hose. machine fills and no leaks. however i can’t locate this pipe with flap at the end the link mentions. that might be the problem?
    thanks and sorry
    #249973
    karv
    blue air break has the flap and tube that causes e2 fault
    white air break don,t have the flap and tube that causes e2 fault sorry brain going abit slow just 2 / o rings that leak no tube or flap on white air brake models
    #249974
    veloce
    it seems it’s sprung another leak – water trickles out at the edge of the machine in operation by the time i’ve drained and turned on it’s side i cannot tell where it’s leaking from. most annoying
    #249975
    veloce
    the immediate problem appears to be a door seal leak now. any tips on replacing these please ?
    #249976
    karv
    this sounds like u gona need a engineer or get rid of machine everthing u had i suspect is linked to 1 problem
    do u have both left and right angel plastic bit in at bottom of door seal?
    door seal i doub,t u need , is water comming from hole underneath most likely the o rings need replacing if it the 2 o rings model ,don,t have a system accesss to check which of the 2 u have going by model number as there are 2 types so going by memory
    if water is pouring out from bottom of door after while , while its filling i think this is ya same first problem and u gona need a engineer to look at it
    ps if u got the 2 o ring white air brake model if washer leak u need to replace them cleaning them and putting back does not work.
    everything u listed are sysmtons of the problem need to find the problem
    i suspect is a leak related low insulation on ya machine normal compoent is motor on low insualtion and air break o rings for leak and low insulation screws ya module up while running and cause it to do anything .
    i do think u need to get it checked out by engineer before u throw any money on parts but i suspect will not be a cheap repair
    #249977
    veloce
    had the door seal off and back on. i doesn’t leak until the thing gets part way through the soak program i think it’s all related to overfilling – whats the part i need to replace that senses the fill level? float switch appears ok – no water in it. thanks
    #249978
    veloce
    it seems that the machine continues to fill and that the pressure switch if activated during this process does nothing. can anyone tell me how to test the switch with a multimeter please? thanks
    #249979
    veloce
    it’s now died. started normal wash . all was good then sounded like and arcing noise then dead. fuse is ok but no lights and no noise. rip diplomat. anyone recommend a cheap but reliable slimline dishwasher? thanks
    #249980
    don
    veloce wrote: anyone recommend a cheap but reliable slimline dishwasher? thanks
    No such thing I`m afraid 😉 , with the word cheap, add Chinese made and won`t last long.
    Take a read of this dishwasher article and the subsequent links to see what we mean.
    HTH
    Don
    #249981
    veloce
    i can get an intergrated replacement from mfi for £329 – any guesses as to whose behind these latest models?
    #249982
    Chinese I’d expect, not recommended but a model number would help offer more information.
    veloce
    kwatt wrote:Chinese I’d expect, not recommended but a model number would help offer more information.
    FROM THEIR SITE
    Name:
    Diplomat
    SKU:
    ACA9102
    General Description
    * • Half load button • Low salt and rinse aid indictors • 2-6 hour time delay • Anti over-flow device • Cold fill • 6 programmes: • Pre wash • Rapid – 40°C • Delicate – 50°C • Normal wash – 55°C • Glasses – 55°C • Intensive – 65°C
    Price:
    £329.00
    obviously the mrs values the integrated look more than anything – i’d prefer it not to blow up…
    #249984
    Yep, Chinese and it’s rubbish. 😉
    HTH
