adp 8902 problems
Viewing 15 posts - 1 through 15 (of 30 total)
  • #36194
    veloce
    Hello
    firstly great forum. i have an adp8902 and it’s currently got issues.
    i have light 1 on and light 5 flashing.do a reset and 1 lit and 5 lit – then quickly 5 starts flashing and then it sets about some kind of program. all seems fine and then when this program finishes i have lights 2 and 3 on and 5 flashing.
    various other button presses and resets seem to result in overfilling….
    thanks for any help you can give
    Julian
    #249956
    Re: adp 8902 problems
    You are not doing a re-set, you have the machine in test mode. Your actual error is that the Aquastop sytem has been activated by water leaking into the base.
    Power off, drain base, find leak.
    veloce
    Penguin45 wrote:You are not doing a re-set, you have the machine in test mode. Your actual error is that the Aquastop sytem has been activated by water leaking into the base.
    it doesn’t seem to leak anymore (well it was but i fixed that)but i can’t seem to reset ? how can i get out of test mode to try a program?
    thanks
    #249958
    veloce
    at end of test mode i now have 1 and 3 flashing and 5 steady!
    #249959
    veloce
    and now 1,2,3 flashing 5 steady !
    #249960
    veloce
    and finally just 1 flashing… it’s an impressive display !
    #249961
    karv
    may be thinking of the wrong machine here if this sounds about right hope it helps some ( if not ignore.) ps my grammer is bad.
    going by memory is it a slimeline dw red led lights ?
    if it is try holding down the programme button for 10 secs and it will cancel any programe it stuck in and u get …** on leds.
    to reset pcb ie test programe turn machine of then back on and before light comes on u have to hit the programe button either 4 or 5 times fast before the light comes on and u get *…* on the display on some models u hit programe once more to get 1 light *….. or …..* forgot which way then you tun the machine of then back on and hold button down again to clear any programeand get ….** again.
    it been know that if programe is in test programe it will over fill in on slimeline machine as it fills to full machine level.
    people trying to use the 70.C wash hit the button to many times before it comes on and bang u in test programme.
    low insulation on motor/machine has been all so know to start a test programe normally due to leak thats been in base and made the motor get wet and sucked the water up.
    #249962
    veloce
    Still got the same problems same sequence of lights. can’t seem to get it out of this mode.
    #249963
    1, 3 & 5 is a failure to fill.
    HTH
    veloce
    i can’t get it to reset properly. reset results in 1 on 5 flashing every time. it then starts and runs through some process if i let it.
    thanks
    #249965
    veloce
    and now as it runs it’s 1 on and 2 on and 5 flashing…
    #249966
    That sounds like an E2 error, if you do a search here you’ll find out a lot more.
    veloce
    had a search for “e2 error diplomat” looked a lots of results couldn’t find it – can you suggest better search term please? thanks
    #249968
    That’s because we get asked about it loads of times. 😉
    This should help I hope
    veloce
    kwatt wrote:That’s because we get asked about it loads of times. 😉
    i can imagine. i removed the side fill it was leaking by o rings cleaned out with hose. machine fills and no leaks. however i can’t locate this pipe with flap at the end the link mentions. that might be the problem?
    thanks and sorry
