adp5540 whirlpool d/w
  • #44592
    Galway
    i called to this today it was not taking in water and the start button was flashing 7 times .i checked the solenoid valve and discovered it was broken so changed it but now it starts to take in water but then stops after about 10 sec and the start button flashes 7 times which is the flow meter.will changing this solve the problem or am i missing something?
    #281523
    robbra
    Re: adp5540 whirlpool d/w
    Yep,
    flow meter.
    Rob
    #281524
    Galway
    does anyone have the part no.for this flow meter
    service no is 854254015750
    thanks
    #281525
    Alanj
    Hi Galway,
    part number for water chamber complete with flowmeter 481241868147 @ £40.74 +vat in stock from Connect or 45.36+vat from Masterpart normally in stock. HTH 😀
    Alan
    #281526
    Galway
    thanks but can the flow meter be ordered on its own?
    #281527
    A1engineer
    Galway wrote:thanks but can the flow meter be ordered on its own?
    not as such, you could buy the reed swith from maplins and solder it in yourself, ive got some on order should be delivered soon so watch this space 😉
    #281528
    Galway
    do you know which reed switch it is as this job is not near me
    thanks
    #281529
    A1engineer
    Galway wrote:do you know which reed switch it is as this job is not near me
    thanks
    ive read on here its CL37 but not tried it personally, hth.
