Re: ADP8132 – Door won’t lock/Lights flashing continually
The door latch is what is called a “turnover mechanism”. The latch part should turn over when the dor is closed. If you can see two “prongs” looking at you when you peer into the opening at the top of the door, the latch mechanism has probably failed. If you can only see a strip of plastic pointing up, the lock is in the engaged position and need pulling down to reset. The position of the striker on the body of the machine will need to be checked for full engagement if this latter is the case.
Check that first, then we’ll deal with the lights……….
