hi there.
there are tons of info regarding this on the forum. the plow meter is located in the panel on the left side. normally it will have two thin white wires attached to a circuit board which is shaped similar to a mobile sim card. on it there is a small reed switch which may be faulty, or the contacts may just need a clean. if you do a search you’ll find many more opinions on this.
keith
