ADP8322 Dishwasher Problem
  • #36748
    subs
    The customer says that this machine, when put on any programme, sometimes “near the end at the drying bit”, starts continually beeping and the pre-rinse light lights up instead of its programme light. I checked everything but could not find any faults, i even sat for 30 mins while it completed quick wash and came to the end as it should with a couple of bleeps and only quick wash light on. She said that the fault normally accurs on the quick wash too. I know this machine shows fault code via tha start button light but this isnt showing any fault. Its one of those ones where the customers explenation is a bit vague and you cant work out whether the faults with the machine, them, or you. Any ideas anyone?
    Subs
    #252168
    DentedPorsche
    Re: ADP8322 Dishwasher Problem
    Whirlpool machine. You can run the engineer test program (in the Known error sticky).
    Any error it reverts to the rinse program and the start light flashes an error code.
    Brian
    #252169
    IME, nearly all unexplained failures on these are due to the water indicator being blocked and not registering that the water has drained out. Assuming the switch of the WI is ok it does not normally show a WI failed error. Only way to be sure is to replace it.
