ADP8322 motor
  • #44495
    timdowning
    Changing the motor on one of these. Its got the BIG ASKOLL type in at the mo.
    Is it a straight swap as all thats in the box is a motor on a mount?
    Thanks in advance.
    #281175
    deltra
    Re: ADP8322 motor
    yep, allthough you will need a couple of jubilee clips (slim ones are best fit) also the bracket on the back of the new pump should be screwed to the rear of the machine. 8)
    #281176
    A1engineer
    Re: ADP8322 motor
    if you are carefull with the old clips you can reuse them,
    straight forward job tbh, youll need 2 screws to attach new motor to back panel, it slots in and pushes up till screws line up, attach hoses and test.
    20 minutes tops..
    #281177
    deltra
    Re: ADP8322 motor
    hi a1 how do you reuse those clips? is there a tool for that?
    #281178
    A1engineer
    Re: ADP8322 motor
    yeah you can get a tool, but you can get away with using a small screwdriver to open them and a pair of snips to close again.
    #281179
    timdowning
    Re: ADP8322 motor
    Cheers.
    #281180
    funkyboogy
    Re: ADP8322 motor
    any one know where you can get slim jubilee clips from
    tried a few places myself..
    ally
    #281181
    cornwell40
    Re: ADP8322 motor
    Perrys, Vauxhall dealership.
    TC
