ADP8332 F9
  • #60527
    Toni
    I have to call to this dishwasher with the F9 faut code
    Any ideas on this (Icant find it on the fault code book) ?
    Regards
    Toni
    #342589
    whiskey_six
    Re: ADP8332 F9
    ADP8332 is a Whirlpool product so I think the following may be applicable
    8)
    Whirlpool Dishwasher Error codes.
    F0. 10 flashes. Sensor Break (Only shown in test programme. Not visible to customer).
    F1. Single flash. NTC Break. NTC open circuit/short circuit or ambient temperature less than 3
    Celsius
    F2. 2 Flashes. Water leakage. Floater switch LS6 in drip tray has switched.
    F3. 3 Flashes. Heating system defect. Heater or relay on control board defect. Check also cabling.
    F4. 4 Flashes. Draining failure. Drain pump, control board OWI or water indicator defect.
    F5. 5 Flashes. Spray arm Blocked (not present on VBL version. On 1 digit display will show as F
    and flashing start led).
    F6. 6 Flashes. Water valve (WV1) is switched on but flow meter (FM) senses no impulses (less
    than 10 impulses in 10 secs.) and the water indicator (WI) is at a low level
    Water Valve Closed. Water inlet hose blocked.
    Water inlet valve (WV1) defective. Flow meter (FM) defective (leads to FM failure)
    F7. 7 Flashes. Flow meter failure. Flow meter defect. Water inlet valve defect or water inlet hose
    blocked.
    F8. 8 Flashes. Water level failure. Sieve strongly dirty or big amount of foam inside to less water.
    F9. 9 Flashes. Continuously Water Inlet. Water inlet valve mechanically not closed or control board
    defect.
    FA. 11 Flashes. OWI failure. Dirty OWI lens. OWI defect or control board defect. Check cabling.
    FB. 12 Flashes. Motorised Diverter Valve
    FC. 13 Flashes. Water Hardness Sensor Failure
    A fault with no fault code indication = faulty module
    These codes should cover the entire range of Whirlpool dishwashers.
    Test Mode
    Make sure the appliance is empty of water before running Diagnostics as it does not
    pump out before starting to fill and therefore you could overfill the appliance.
    Open the door and set the program to the first program. (Normally rinse).
    Turn the power off.
    Press and hold the start button and while holding turn the power on.
    After a little while the start button will flash, release the button.
    Press the start button once and close the dishwasher door.
    The machine will now run through a diagnostic routine.
    If memory serves me right it takes about 20 mins.
    The machine will stop during diagnostics if an error is found and will display the error code. If no
    error is found it will complete the diagnostics and end the programme.
    To exit diagnostics at any time just press and hold the start button till the programme is cancelled
    #342590
    happycack
    Re: ADP8332 F9
    Found this on the net. Not sure of its source. Anygood?
    Is fault F4 easy to cure or does the dishwasher need replacing on Diplomat ADP 8332 ?
    S Dagg
    August 2007
    Hi, Fault Codes F1 Faulty NTC
    F2 Water leaking underneath
    F3 Heating fault
    F4 Drain pump failure
    F6 No water supply
    F7 Flow meter failure
    F8 Overfilling
    F9 Water valve not closing
    Hope this helps
    #342591
    Toni
    Re: ADP8332 F9
    Thanks for the promt replies
    that should do the trick
    Toni
