Adp8342
  • #90227
    Marie.UK
    I’m hoping for some help!
    I have the adp8342 dishwasher. Over the years I’ve had the usual issues, soap powder, water not draining. However I’ve had it for nearly a decade and generally if got an error message it would be the first three lights and if I left it for three or four days it would be ok again for many months.
    In the last ten days I’ve tried leaving the dw but it hasn’t worked!
    The dw was mid a typical cycle. Alarms went off, ten beeps and six flashing lights.
    It doesn’t make any noises as though about to start – but can feel the machine vibrating with my hand on the door. It did once start a new cycle after I did the reset thing with the function and on/off button.
    I read above that it could be to do with the door? If so am I capable if revisiting this? (Money’s tight so would prefer to avoid an engineer call out), if it required pulling it out, is there a diagram anywhere of exactly what I need to do?
    Thanks in advance.
    #444110
    Marie.UK
    Re: Adp8342
    Can anyone advise?
    #444111
    char14lew
    Re: Adp8342
    first thing I would do is take the inspection plate (bottom front) off and see if there’s water in the base?
    isolate from mains first of course!
