The first 2 lights on the programme Indicator starts flashing and the machine starts bleeping after about a minute of the machine starting a programme any ideas?
Check that water is on and that fill hose is not trapped, nipped or kink. Possible that valve has failed, or that the pcb is not actually switching it on.
Penguin45 wrote:No fill detected in the time allowed.
Hi I have the same problem and have checked the water and fill hose, they are fine. Is there a way to test the valve and/or pcb?
Cleaned the valve and managed to get a cycle to start and water to enter the machine. Worked for about 10 minutes then multiple beeping and the two program lights on the very left flash like before.
