ADP8352 Door lock problems
  • #90948
    char14lew
    Anyone had problems with the door shutting on these things?
    It just springs back when trying to shut- i’ve changed the lock and latch to rule them out but still doing it. I can’t see what can be stopping it?
    It’s this type.
    #446562
    Re: ADP8352 Door lock problems
    bent door hinges ?
    are both door springs attached ?
    also take out baskets first in case its them
    char14lew
    thanks Dave, did the baskets thing, feels like plenty of tension on the door from springs. Didn’t check hinges though. Even without tension from anywhere else, the lock should still clamp the latch with hand pressure on closing.I’ve tried the latch in different positions also. I’ll go back and have another look!cheers
    #446564
    had a few hinges bend and it causes this problem so its likely door has been strained. door wont feel any different as it will not affect the springs etcetera but the hinge reaches its closed position before the latch engages. After that your just bending things to try and close it and as you realise it wont
    grooster
    Its like electrofix says, its either bent hinges or the baskets are in wrong way around / loose wheel stuck in the runner.
    The door may have been stood on by a child when open. I have in the past bent them back into shape a little by placing a small handled screwdriver next to the hinge at the bottom and pressing the door against it, pushing the door at the top. Repeat for both sides. Not the ideal solution but would give you an idea if it is the hinges or not.
    #446566
    johnnyj
    It will be the long hinge bar twisting, used to get it loads of times on the Indesit dishwashers connect part no 5031680016468 JJ.
