Advice / manual for Diplomat ADP3340 Oven
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Advice / manual for Diplomat ADP3340 Oven
  • #36851
    jonmc1980
    Hi, everyone I have recently moved into a new house which has a Diplomat ADP3340 oven. However there is no manual and the markings around the controls have worn away. I have no idea how to control the oven functions or what temperatures which. If anyone could provide advice or send me a copy of the manual i’d be very grateful! thanks
    #252571
    obelyskdan
    Re: Advice / manual for Diplomat ADP3340 Oven
    Hi there, I know this was posted several years ago but did you have any luck obtaining a manual for this oven? I’ve just moved Into a house and am having the exact same issue – no manual and worn off dial information.
    Fingers crossed you receive this, can’t find a manual online anywhere!!!
    Thanks for your help
    #252572
    steev
    I know this is eight years out of date but you may be in luck – I have the same problem and found the manual here: http://www.inter-spares.co.uk/diplomat/diplomat-cookers/adp3322/instruction-manual-1-2-3-4-5-6-7-8-9.html (it says ADP3322 but is also supposed to cover the 3340)
    I checked mine against an oven thermometer and the temperature is best described as 50 (the minimum) at about 1 o’clock, 250 (the maximum) at about 9 o’clock with 100 at about 3 o’clock, 150 at 5 o’clock and 200 at about 7 o’clock. However I have no idea what the right hand knob or the clock buttons do! I’ll update this if I receive the manual above and describe it.
