Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Advice on a narrow machine (between 50-55cm)
- This topic has 5 replies, 5 voices, and was last updated 17 years, 6 months ago by
ccshell.
October 7, 2008 at 8:11 pm #40036
ccshell
ParticipantNew to the site and would welcome a bit of help please.
In my new kitchen, I only have an aperature of 60cm to fit a washing machine in and i’m scared to put a 59.5cm machine as once it starts spinning, it’ll destroy half the kitchen. Ive looked on the websites and most machines are at the standard 60cm but I have seen two which look OK – Zanuzzi ZWC1300 and the Servis M9530.
Can anyone recommend any others between 50-55cm wide that would fit?
Must say the lack of choice I find staggering. I would have thought loads of people with space issues need smaller, compact machines – the manufacturers are missing a trick here.
Any help would be most grateful.
ccshellOctober 7, 2008 at 8:33 pm #264510Penguin45
ParticipantRe: Advice on a narrow machine (between 50-55cm)
600mm x 850mm is the ISO standard sized hole……. Depth is the only consideration to be worried about.
Please don’t but the Servis.
October 7, 2008 at 9:51 pm #264511iadom
ModeratorRe: Advice on a narrow machine (between 50-55cm)
Penguin45 wrote:
Please don’t but the Servis..
You can but it all you like, just don’t buy it whatever you do. 😉
October 7, 2008 at 11:36 pm #264512Penguin45
Of course, being a Moderator, you could simply have amended the spelling……
If you buy the Servis, you will end up butting it – the electronics do have comedic value to us repairers.
October 8, 2008 at 7:56 am #264513don
ccshell wrote: Ive looked on the websites and most machines are at the standard 60cm but I have seen two which look OK – Zanuzzi ZWC1300 and the Servis M9530.
ccshellHi
Just be aware that the Zanussi is a compact washing machine with only a 3kg load which measures 670mm high, 495 wide and 515 deep. Bosch cabinets amongst others are 595 wide so it should not be a problem 😉 .
HTH
Don
October 8, 2008 at 10:49 am #264514cockney steve
If your cabinets are properly fastened to the worktop, either side of the opening, you’ll have an EXTREMELY rigid “box”for the machine……if it jumps around enough to damage the units, the machine’s installation or user-operation is seriously suspect.
