Advice on fixing Hotpoint Aquarius not drying fully
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Advice on fixing Hotpoint Aquarius not drying fully
  • #99878
    Allan Stevens
    Would anyone be able to offer some advice? I have a Hotpoint Aquarius tumble driver model AQC9BF7S1.
    It heats up as expected at the start of a cycle but after about 10 minutes the heating part stops but the cycle continues. It will only heat up if I cancel the cycle and start again.
    I had thought it was just the thermostats so I have replaced them, no change. I have then bought a replacement kit with the element, thermostat and humidity sensor, once fitting I still have the same issue.
    I’m at this point I’m really stuck? could it be the circuit board? I don’t really want to spend anymore money on it asit’s getting very expensive! I was just wondering if you have any advice on how to get this working?
    Thanks, Allan
    #478277
    you mean it continues cold ?
    how long does it run cold before it decides its the end ?
    what i am thinking is it decides its dry enough and goes into the 10 min cool down phase and stops
    is the condenser clear both ways, mainly front to back ?
    shine a torch through the condenser and make sure its clear
