Advice regarding central heating pressure… (old system)
Home Forums Public Support Forums General Enquiries And Questions Advice regarding central heating pressure… (old system)
  • #95358
    diyclown
    Hello,
    This is not exactly an appliance question but maybe someone can offer some advice. I bled the radiators recently and now the pressure reading is 0 (it should be 1.5). As a result the radiators are not getting fully hot especially upstairs. I cannot remember how to increase the pressure again.
    https://postimg.cc/N5kp2F08
    In this pic you can see a small black switch or valve just under the grey washing machine hose. Is it this I use ?
    or
    https://postimg.cc/k25FVyz9
    In this pic you can see the expansion vessel and pressure gauge. I was thinking it might be the red cap above the gauge that I use? If so how do I use it? Direction etc ?
    I seem to remember it was one of these the heating guy used when I was shown along time ago.
    I’d really appreciate any help you can offer.
    Thanks very much.
    #460130
    I would turn this tap and see what happens. if it does start to rise do not let it get above 1.5. I would let it get to just over 1 and see what happens from there
    diyclown
    Thanks for your reply. I assume this adds water to the system does it?
    #460132
    correct but its important to only add enough and not too much and do not leave the tap turned on under any circumstances
    diyclown
    OK Dave. I’ll give it a try hopefully later today. Thanks.
    #460134
    diyclown
    Sorry I’ve not replied sooner. I managed to add some water using the black tap as you suggested. All seems to be OK at the moment. Thanks very much for the help.
