Re: Advice wanted on Teka DW6 59 Problem
Interesting question. Most recent SMEG built machines have a tube type heater under the tub, therefore, there is nothing in the tub itself to spark off. Yours (of course) may have a heater in the tub – tech info on these is just non-existant. If it does, check for cracks, blow holes or “fizzing”. Otherwise, I’d start by removing the outer door and checking the wiring loom at the hinge area for breaks. Failing that, you need to get to the base tray underneath and check for evidence of water leakage.
Can’t tell you much more based on your post.
Stay safe, power off first.
