AEG 1051 Sensotronic
  • #36604
    pscwhite
    The bearings are dead. I now have some new bearings but having removed the pulley and taken out the 6 bolts that hole the Spider it does not seem to move. Do I have to split the drum or should the spider come of the back?
    #251638
    Re: AEG 1051 Sensotronic
    The drum shaft is an interference fit within the bearings. You will need to protect the end of the shaft and drive it out with a big hammer, whils pulling the bearing spider towards you.
    pscwhite
    Thanks. Just for anyone else trying – they have made the spider bolts push the edge of the drum into recesses in the end of the spider so it does not pull out. Had to use a thin piece of steel and carefully straighen the indents!
