aeg 1271 sensotronic fault
  • #22796
    suedehead1
    ive got a problem with this integrated aeg 1271 sensotronic it has the number 1 in the display no letters just the number 1.
    after mucking about for a while in emptied and spun then when i put it on to wash it fills up then the number 1 appears immediately.
    anybody give me a clue before i rip it out.
    ive cheacked it wasnt on a delay start or anything obvious.
    #196180
    Re: aeg 1271 sensotronic fault
    If you always quote the Enr or Pnr it makes it a lot easier for us to try and help.
    #196181
    timdowning
    I have a similar fault on one of these:
    PNC 914676001/00
    Apparently does rinse cycle and spin cycle ok. But on any wash cycle it brings up 1 in the display virtually straight away after starting.
    My first thoughts are valve related.
    I don’t seem to have a diagnostics for this machine on my TDS disc.
    Thanks.
    #196182
    There’s some info on mediator for 1261sensot. but it may be different (not same PNC). It has a hybrid timer VA20/30 and a test cycle with step 1 being fill and not much else. Wondering if yours is stuck in a test cycle waiting for you to do something?
    Mike.
    #196183
    timdowning
    Thanks, I will take a look.
