AEG 16830 Door issue
  • #82393
    dragonfire709
    Our trusty AEG has just developed an issue that has me stumped-hopefully you guys can help. The door suddenly stopped locking, so wouldn’t start any program. It would occasionally show code E40, but not consistently. I instantly thought this would be caused by the interlock, so bought a replacement. When I went to fit the replacement i noticed some burn marks on the interlock connector. I replaced the interlock anyway, but as suspected this didn’t fix the issue.
    Could this be the end for our poor old Lavamat?
    Cheers
    Roy
    #419711
    Re: AEG 16830 Door issue
    Did you not sort out the burnt connector block then?
    #419712
    dragonfire709
    Hi Martin. I did clean up all the connections but am still trying to source a replacement block or loom. My main concern was that the connection looked burnt out and whether that was a symptom of bigger issues.
    Cheers
    Roy
    #419713
    No bigger issues just a poor contact that can be sorted with a new connector. Give me the full product number (PNC) of your appliance and I can look up the part number of the new lead if you like.
    #419714
    dragonfire709
    Hi Martin
    Thanks for your help. The PNC is 914602122/01.
    Cheers
    Roy
    #419715
    The part number of the wiring harness to connect the door interlock is 1322416122
    #419716
    dragonfire709
    That’s great. Thanks Martin will have a look for it now.
    #419717
    dragonfire709
    Many thanks for your help, Martin. I finished fitting the loom last night, fired it up and it’s all sorted.
    Cheers
    Roy
