Called to this autowasher today. Set prog door locks, pumps for approx 30 secs then just sits there with the door light constantly flashing. Any ideas guys ?
As a rule the END LED and START/PAUSE LED flash to give the error code. You didn’t mention either so you will need to check the most likely suspects first i.e Motor brushes? Heater?Inlet Valves?
If it is a washer dryer, though your title suggests not, first check ins res of drier heater and try disconnecting it if it’s below 30 megs. or even below 50. If it’s just a washer, is there condensation on the brush holders?
💡 Er, had any rain lately where you are?
Mike.
