aeg 16850 w/d dead pnc914605309 01
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries aeg 16850 w/d dead pnc914605309 01
  • #71589
    mikehha
    Good evening all. I have a w/d that I was called too because they said it was not draining.When I got there it wasn`t draining because it was dead no display no door lock but power going to the control board . Has anyone come across this befor.As I can see there is three pcb`s none of which look burnt or have any dry joints. any ideals!
    #381586
    Seamy
    Re: aeg 16850 w/d dead pnc914605309 01
    Most likely the EWM2500 main control board, power comes in on the U3 plug which is mounted sideways, plug has green end on it I think, there is an on/off action switch built in to the programme selector.
    Not much you can do with the P.C.Bs except swap over, but is theres a 4 tag door interlock i’d change it too.
