AEG 3030B-W oven
  • #28071
    RickT
    Hi all, Having a bit of a brain teaser with this one. The timer and oven are cutting our whilst cooking. Cooling and oven fan motors both functioning, oven thermostat controls correct temperatures, toc on the cooling vent ok. On checking the rear toc, found it was burning out and fell to pieces on removing the wires. Fitted new toc (Part No: 3117523054) rated at 180 degrees. Still got the same problem!!! The same toc is still cutting the timer and oven off before it has a chance to heat to 220 degrees .Once the oven cools for a few minutes on comes the timer again. I’m confused as to why this toc is rated at 180 degrees and the oven stat is capable of reaching 250 degrees. Has anyone else had this problem, all help appreciated.
    Rick
    #216759
    comptonappliances
    Re: AEG 3030B-W oven
    had this b4 if timer display cutting out as well it will be one of the two control pcbs got caught out myself changed loads parts under insurance not the way to go i know but got there in the end
    #216760
    comptonappliances
    ignore last message getting tired thinking of wrong model check theres not another stat at rear hidden under cavity insulation hard to c sometimes
    #216761
    RickT
    Hi, I’ve doubled checked. Just one toc at the rear right hand corner, one toc and a thermostat on top on the cooling duct. For testing I bi-passed the rear toc to get the oven up and running.
    Thanks Rick
