I put it on a quick wash and it heated fine. I took the board out to look for dodgy solder points but all was ok. Loom & heater ok as well. Pinched the connector on the temp sensor.
Apparently it did one wash ok but is now not heating again.
I’m quoting for a module but wanted to see if anyone has had the temperature sensor in the sump give an intermittant no heat.
To be honest no. No user error was displayed, went through cycle and ended but no heat at end. (On 65oC wash.)
The 30 minute wash worked fine for me.
Do you have diagnostics for this model? Ta.
