Re: AEG 31004W Double oven temperauture
Sounds like it’s shutting off early – cycling on the safety rather than the operating stats. Can you hear the cooling fan running – or feel the draught? Insufficient airflow through the oven casing can cause similar problems.
Be warned that whilst there may well be a problem with the appliance, if it is down to installation error they will charge you!
Otherwise it’s under warranty, so get them out to it.
