AEG 33600 dryer belt – how easy is it to replace?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum AEG 33600 dryer belt – how easy is it to replace?
  • #52189
    mariam44
    My hard working AEG dryer has come to a grinding halt as the belt has broken. Replacement belt arrived from uk whitegoods today, but I need some tips on putting it on. Any help gratefully received!
    #310893
    Re: AEG 33600 dryer belt – how easy is it to replace?
    Not the easiest dryer to work on. You take off the lid and left hand cabinet side then you need to remove the fans from both ends of the motor shaft, remove the motor, and refit it with the new belt in place. Good luck, you may need it!
