AEG 3888-8KG Temp Sensor
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum AEG 3888-8KG Temp Sensor
  • #63973
    trevalex
    After getting an Engineer from DomexUK came to charge me 35quid for telling me what I already knew from the AEG site that the Temp sensor had failed on my fridge.
    DomexUK called told me, parts don’t exist for this fridge any more scrap it and buy a new one..
    After some more online searching I have located the temp sensor at this site:
    http://www.inter-spares.co.uk/aeg/aeg-refrigeration/s3888-8kg-924519321-/sensor-air-temperature.html
    I am trying to find a service manual to guide me through replacing this but can’t find one.
    Can anyone give me some pointers to check the best way to get at the sensor to swap it out.
    I.e. from the back or near the light ?
    Thanks in advance.
    #355695
    Re: AEG 3888-8KG Temp Sensor
    according to service manual there are 2 sensors in you fridge and 1 in your freezer
    there is an air sensor and an evaporator sensor
    from manual fault diags
    look at front display on fridge if there is a 0 in the top of the dislay its the evap sensor if its in the bottom its the air sensor
    some of these sensors may be foamed in and require foam digging out and replacing
