91193562704. The hose from the sump to the circulation motor has split. The hose on this model comes part of the sump and the sump end of the hose is bonded on, the other end is spring clamped to the motor. I ordered a sump in the hope I could remove the hose from the sump saving me the hassle of changing the sump complete. I was then going to jubilee it to the old sump. Unfortunately it won’t unbond. Im sure I’ve seen the hose spring clamped both ends on newer versions, would anyone know the part number of the hose? Ta.
