aeg 40650 (favorit)
  • #20621
    dippy61
    Afternoon all,
    above is about 2 yrs old and has suddenly stopped heating the water and/or drying. Ive had a quick look and no obvious wiring issues, although searching through the posts it doesn’t appear to be a common fault, therefore any ideas would be appreciated.
    Regards
    Dippy61
    #187747
    Re: aeg 40650 (favorit)
    Dry joints on computer board or heating element failure would be the most likely problem.
    Power off if investigating.
    dippy61
    thx for reply,
    heating element- yep, happy to replace if required (i’m hoping this is the most obvious fault.
    dry joints on comp board-could you elaborate, sounds cheaper so should investigate further, ie access, what to check for etc.
    thanks in advance. dippy61
