Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Aeg 40850 Dishwasher not heating water
- This topic has 8 replies, 3 voices, and was last updated 16 years, 7 months ago by
Unlucky day.
September 1, 2009 at 11:07 am #48218
Unlucky day
ParticipantReading up about this online it seems a common fault, but help required. The control unit I believe costs over £100. A call out charge another £50. toying with repair or replace if this is the case.
I have removed the pcb and underneath the relay 2 points look discoloured, although well soldered ( no expert mind)
Is there any way i can check if this is definately faulty?
I have also located the heating element in the back. not sure what to test here with the multimeter.
The plug in plastic connector has 2 metal contacts on the element body – reading 0v. Unsure of where to test for the resistance as these points have no resistance indicating dead heater element I believe. heater also has earth i believe and a strange pipe like connection which goes around the element body
photos below –
heater –
Pcb –
unknown connector on heater and wiring diagram
September 1, 2009 at 12:55 pm #295968martinm
ParticipantRe: Aeg 40850 Dishwasher not heating water
I need a bigger screen
September 1, 2009 at 2:15 pm #295969Unlucky day
Sorry – about sizes of the Pics
Now resized – help appreciated
is it the pcb or is it the heater is what i am trying to test for?
September 1, 2009 at 7:33 pm #295970Penguin45
Test meter across the heater terminals should show c.25ohms. If you get that, you can eliminate the heater.
September 2, 2009 at 3:46 pm #295971Unlucky day
I presume the heater terminals are where the white clip connects to the heater body and are +ve and -ve and you test with power off.
just there is also an earth connection and a long hard wire connection that travels the length of the element also.
Also the pcb is out of the machine too, does this matter
Thanks againSeptember 2, 2009 at 8:09 pm #295972Penguin45
Pull the connector plug out of the heater and measure thee resistance across the two terminals revealed. That’s all you have to do…..
September 5, 2009 at 12:19 pm #295973Unlucky day
No resistance measured – Guess the heater is no good.
If i replace it – any idea how to remove the black hose attached to the element. It’s a 3way hose but how do you get the clips off at the far end, access is poor and it’s too far away too reach easily.
everything else is disconnected.
September 5, 2009 at 9:31 pm #295974Penguin45
It’s b’ awkward – those spring rings are viscious. I rather think I removed the hose on the last one I did, hooked up the heater, then put the hose back. Still a swine……
Part number for heater is 50277796-00/4 – spares@ukwhitegoods.co.uk will be able to get you one promptly.
October 6, 2009 at 7:15 am #295975Unlucky day
Cheers penguin45
All sorted just the faulty element, removing the clips was the hardest part.
thanks again 🙂
