Reading the handbook it appears the anti-flood unit has tripped. I hope some one can tell me how to reset this. I have removed all panels so have a clear view and I’m still not sure where it is.
Machine was badly blocked in the waste outlet, I have now removed all pipes and filters and cleaned thoroughly.
Now the machine will not run OK. Pump runs all the time and no water is taken in.
Any help very gratefully received
Dave W
Shoud just be a polystyrene float under a microswitch. Check that the float is not floating or jammed and that the microswitch “cage” is properly mounted. If you disconnected it to gain access underneath, have you put the wires on correctly?
