I initally had the anti flood alarm with 3 beeps, this was easily traced to a split pipe near the heater. Having replaced the pipe the machine now thinks it is full of water and stops with the 2 beep alarm.
If I disconnect the heater electrical connection the machine runs fine, if I reconnect it stops with the 2 beep alarm. What I don’t understand is that there appears to be a wire running from the heater to the pressure sensor, so maybe the heater and the fill problem are linked. The heater resistance is about 30 ohms which I believe is correct.
Can anyone help?
Many thanks,
Tim Roberts
