Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › AEG 49002VMN Cooker.
- This topic has 9 replies, 3 voices, and was last updated 6 years, 3 months ago by
JayCee9.
December 18, 2019 at 8:34 pm #96906
JayCee9
ParticipantWhenever the main oven fan is used it trips the RCD in the fusebox. If main oven cooking is selected without fan assistance the oven heats/works normally, it only trips the RCD if the fan is used and it trips after about 30 secs. The motor blade turns freely.
I suspect the oven fan motor but would like confirmation please.December 18, 2019 at 9:13 pm #465302electrofix
Moderatorit looks like you have 2 types of oven in one
fan oven uses a rear circular element
convection oven uses the grill element and another under the floorso its likely your fan element has failed
should be this one but check with shop before purchase
https://shop.ukwhitegoods.co.uk/3878684103-fan-oven-heating-element
December 18, 2019 at 10:42 pm #465303JayCee9
ParticipantThanks for the reply Dave.
as I stated, the lower main oven is fan assisted and the element still heats the oven, the RCD only trips if you select the fan.
Are you saying there are two elements in the lower main oven and it’s the rear circular element that’s causing it to trip?John
December 18, 2019 at 11:04 pm #465304Specialist01269
ParticipantThe answer to both questions would be yes, easy way to prove is to disconnect and insulate one wire from the element then turn on the fan oven. If it doesn’t trip you’ve proved the point.
please ensure that the mains power is turned off before working on the appliance.December 18, 2019 at 11:25 pm #465305JayCee9
ParticipantSpecialist01269 wrote:The answer to both questions would be yes, easy way to prove is to disconnect and insulate one wire from the element then turn on the fan oven. If it doesn’t trip you’ve proved the point.
please ensure that the mains power is turned off before working on the appliance.Thanks, I’ll take it apart tomorrow and check it.
I’ve been repairing TV’s all my life and will, of course, make sure the cooker is isolated from it’s mains supply.December 19, 2019 at 6:24 am #465306Specialist01269
ParticipantHope you get it sorted, thinking about it it would be better to disconnect both wires from the element. If the element comes out from the front, you need to make sure that the wires don’t slip back through the holes. That can be a total pain in the backside, the only problem I can see is getting an element so you can repair it in time for Christmas. Good luck & please let us know how you get on.
December 19, 2019 at 8:08 am #465307JayCee9
ParticipantSpecialist01269 wrote:Hope you get it sorted, thinking about it it would be better to disconnect both wires from the element. If the element comes out from the front, you need to make sure that the wires don’t slip back through the holes. That can be a total pain in the backside, the only problem I can see is getting an element so you can repair it in time for Christmas. Good luck & please let us know how you get on.
Thanks, will do.
I’m hoping “ukwhitegoods” have a trade counter and have parts in stock as I live quite near Kilmarnock.John
December 19, 2019 at 8:20 am #465308Specialist01269
ParticipantNot sure about that to be honest, but I’m sure they’ll do their best to help you out. They’re really good people to deal with.
December 19, 2019 at 5:02 pm #465309JayCee9
ParticipantWell guys, just to say this is now fixed and the fan element was indeed the cause.
I removed the backplate covering the element and fan blade, removed the two screws securing the element which withdraws from the inside of the oven and removed the element connectors making sure they were well clear of each other and the surrounding metalwork.
I then switched on the power to the oven and selected fan assistance and ran it for about a minute without tripping the RCD whereas previously it tripped after about 15 secs.
Visual checks only showed one slightly dark mark on the element but an ohms check showed it to be O/C.After taking notes of the part no on the element I phoned UK Whitegoods and spoke to a very helpful guy by the name of Alistair who then entered the part no into his database which then showed one original element in stock.
A quick 40 min drive to Kilmarnock and I was at the sales counter, met Alistair (a very helpful and friendly guy) and bought the replacement element with a nice discount off it to boot!
I returned home, fitted the element and was rewarded with a warm oven and no tripping RCD.Thanks to all here for the quick replies and accurate diagnosis and Seasons Greetings to you.
John
December 19, 2019 at 6:22 pm #465310Specialist01269
ParticipantYour more than welcome, glad we could help. Have a great Christmas.
