Pnc:914002586-00
Set to any programme and after a couple of seconds the mains light flashes/beeps five times then repeats.
It will not go into diagnostics mode, still does the same five flashes.
Got the megger out and found dead short on main motor. 😥
Plugged in with motor unplugged and could then select programmes and it would fill and drain, but could still not get it into diagnostics mode.
The cost of a new motor alone is going to BER this machine, just wondered if the motor fault may have damaged the main pcb as well?
