This one has had water leaking through the dispenser to door seal as screws were not tight. Consequently the solenoid has bubbled but now operates all the time(upon switch on). Cust reported oil leaking out of door 😯 . Is the module on the left the control for the solenoid and if so would it have to be configured when replaced? Both modules are made by Siemans. And what is the partnumber for the module? PNC is 91123240701.
Re: AEG 50700-W Melted Dispenser solenoid operates permanent
Simon46 wrote:Consequently the solenoid has bubbled
“Bubbled?” what do you mean by that? What is the PNC of the machine, cos the only Lavamat 50700 I can see has got a small ‘Lamp Module’ and a ‘Timer/Module’ combined?
Thanks for that Clive.
Martin the dishwasher solenoid that opens the soap dispenser lid looks like it has been under the grill it is so melted. There is smoke damage on the PCB above it. Cust has been advised by someone else to continue using it with tablet in the cutlery basket. This could have been nasty. :eeek:
