My AEG Favorit 50730 kept tripping its anti flood valve. I took the left hand side off and found a leaking hose that fed the matrix that runs up the side. Fixed this with a jubilee clip and re-assembled it. Tipped the dishwasher over at an angle of 45 degrees and let the water out to reset the anti-flood valve
Set it off on a cycle and the water pumps out of the sump for a few seconds and then about 60 seconds later the error lights start flashing indicating a mislaid or blocked sink hose.
This is blatently not the case as I can pour a bucket full of water into the dishwasher and it gets pumped out again if I restart the cycle
Any ideas ? Circuit board ?
TIA
Ian
