aeg 50870m/91196619/02
  • #65762
    eng14
    Hello all this d/w had new aqua stop fitted to remedy very slow fill,this did not cure the fault and still fills slow till error i10 appears.need some help on this one please,richard. 🙁
    #361776
    Seamy
    Re: aeg 50870m/91196619/02
    PNC number is incorrect, should be 9 digits, i’m presuming its a Favorit 50870.
    Check water supply pressure to machine. I10 means appliance did’nt fill to level required inside 90secs or 60 secs on some machines. User manual should state water pressure required.
    #361777
    Criscold
    Also check the inlet tank on left hand side
    Pt No. 1170481004 – never had AEG blocked but have had several in other makes.
    Colin
    #361778
    eng14
    thanks guys had feeling it was water pressure to machine, 8)
