AEG 5211V removing door glass
Home Forums Public Support Forums Help And Support Cooker And Oven Forum AEG 5211V removing door glass
  • #87587
    k64
    How should I remove the glass in the oven door so I can clean the internal surfaces?
    AEG Competence 5211V-W, PNC 940 313 032
    Many thanks
    Keith
    #435345
    Re: AEG 5211V removing door glass
    remove the oven door ( see owners manual for how)
    then you will have to remove the screws that hold the outer glass in place
    make sure you cant drop the glass when you do it so use a big table or better still the floor
    k64
    Thanks.
    Presumably that’s all six screws: 2 beside each hinge and 2 on the top edge of the door.
    Keith
    #435347
    k64
    I’ll reply to my own question as no one else has…
    Do NOT remove the screws beside the hinges, only the two on the outer edge of the door.
