AEG 5231bm fan not working
Home Forums Public Support Forums Help And Support Cooker And Oven Forum AEG 5231bm fan not working
  • #80849
    Turbo1
    Hello peeps
    AEG competence 5231bm main fan not working, the fan that blows air out the top comes on and stays on for a while after oven on.
    Oven seems to heat up but not to correct temperature.
    Tried resetting and made sure not in auto.
    Any ideas anyone???
    #414569
    Re: AEG 5231bm fan not working
    Fan motor jammed, worn shaft bearings on it?
    #414570
    Turbo1
    Element on back wall not working neither is the fan behind it.
    Would the fan still work if the element was shot?
    Top element/fan fine
    #414571
    To look into this more deeply for you, you will need to provide the full model number (PNC number). What you have given is not enough/correct. 🙁
    #414572
    Andy jones
    Sorry originally you said it heats up but not enough. Is that still the case ??
    #414573
    Turbo1
    AEG Competence 5231B-M
    PNC number is KD 944. 181 101 – 107/713100
    Yes doesn’t seem as hot but think that’s because it’s just the top element working, the one at the back won’t work.
    I was going to change the element but could it be something else as the big fan behind it is not working either
    #414574
    Andy jones
    Can you hear the fan humming ?
    #414575
    Check out the thermal trip inside. Power off first don’t forget. :zap:
    #414576
    Turbo1
    I don’t think the fan is humming there’s no change in noise when going through all the different settings. The cooling fan comes on straight away and is constant don’t know if it’s normal.
    Not sure where the thermal trip is but would that bd the problem if it was cutting out after getting hot or could it stop the element/fan from coming on to start with.
    Wife now tells me the element/main fan stopped working after a power cut?
    #414577
    Turbo1 wrote:Wife now tells me the element/main fan stopped working after a power cut?
    Good grief!
    #414578
    Turbo1
    Martin wrote:
    Good grief!
    Thanks for taking the time to reply
