aeg 52580b-w oven
  • #98953
    eng14
    hi guys strange one this went to fit new main oven door hinges b4 christmas,all fine changed both as right hand snapped,customer reports the top oven is getting moisture and water inside.richard
    #474481
    inside the oven or inside the door glass ?
    eng14
    hi dave he says on the top oven glass and also inside top oven richard
    #474483
    oven glass i could understand as have heard of that but inside the top oven can only mean moist air is condensing inside the top oven
    is kitchen a cold one or well heated ?
    eng14
    did not think of this dave,did it do it b4 hinges i dont know,you go to fix simple job then get involved in this.richard
    #474485
    been there, its all part of the job and life
    years ago the insulation was so poor compared with today that the top oven would be warm when the bottom oven is on
    probably just cold weather. as long as the door is closing properly after hinge fit then cant be your fault, as you realise
    eng14
    thanks dave
