Model No D5701-4-M
Product No 944171272
Serial No 51100027
Using oven, after about 1/2 hour LED display went blank. Hot air was being blown out between grill and controls. Opened oven door – fan at back was off, oven seemed rather hot – so switched oven control knob to off, but left cooker power on for case fan to disperse heat.
After about 5 mins, the display came back on, showing 12:00_.
About 5 mins later, I noticed a hot smell, and looked in oven – back of inside of oven was glowing red hot, and oven fan was not going.
Soiled underwear, switched off at mains, and left to cool down.
I am concerned that if I had not been nearby, the sod might have set light to my kitchen, even though the oven control knob was set to off.
About an hour later, tried oven again – all appeared normal, with oven fan running, and oven gaining temperature – did not leave it long enough to reach target temp (180C).
Any thoughts?
Thank you.
