AEG 57700 Dryer
  • #35289
    legsthediver
    Belt pulley off pin wen i went into machine…. couldn’t find ANY sort of retaining clip/washer to hold this onto Motor pin… Any Ideas please ???? Regards as usual…. Legs…
    #245863
    Re: AEG 57700 Dryer
    Loctite?
    #245864
    Re: AEG 57700 Dryer
    Had one of these to look at the other day. Nothing holding pulley on except self-centring. That wasn’t the problem with this one though.
    When you put it on any auto-dry setting it packs in after about 20 seconds and the “clean filter” and end lights come on. Seems to work OK when you set it to a timed drying programme though. Needless to say, all the filters, condenser, etc are perfectly clean. Water thing is empty. The dryer hasn’t had much use, it’s in a holiday let. I took off one or two panels and couldn’t see anything untoward.
    Any ideas please?
    Mike.
    PS, PNC 91601409802 S/N 04412176
    #245865
    Seamy
    Re: AEG 57700 Dryer
    leavemetogetonwithit wrote:Had one of these to look at the other day. Nothing holding pulley on except self-centring. That wasn’t the problem with this one though.
    Any ideas please?
    Mike.
    Auto-dry is an AUTOMATIC programme (requires laundry to work) timed runs for set time irrespective of load or no load in drum.
    #245866
    Re: AEG 57700 Dryer
    Thanks Seamy. It seems likely that the cottage guardian or a guest must have just tried it out without washing in and reported it faulty. I’ll get them to test it again.
    Incidentally, I found that all the service manuals and bulletins for this were available on Connect’s mediator so I’ve had a read and concluded pretty much the same. Only thing that throws a doubt in is the filter light coming on.
    Mike.
