AEG 60820 – Power cable
Home Forums Public Support Forums Help And Support Dishwasher Help Forum AEG 60820 – Power cable
  • #96211
    ryansmcfadyen
    Hi all,
    Have an AEG 60820, recently moved and when it was pulled out from the old place the power cable must have snagged and came straight out the back of it.
    Cable & connectors look fine to me, figured I’d just open up the unit and connect it back up – but for the life of me I can’t find where I might do that. Can’t see any terminal box or open connectors for it.
    Any ideas?
    Cheers
    #462692
    chances are there will be a mains suppressor which will prob be a plastic tube (approx. 30mm dia) with electrical connections on it. find this and there will be space for your cable
    you could post pics but they may be too small to see properly
    ryansmcfadyen
    From what I’ve managed to figure out there’s two connections at the back, in a plastic bracket – literally the only two possible places power could go – takes Live/Neutral through a cylinder like you describe (although metal with no markings) then down to a relay (eberle 669808049) which splits off to the control board and water heater.
    Machine powers on and runs with the Live/Neutral connected to them.
    Question I have now is; would it matter which way around the live/neutral are connected to the terminals?
    #462694
    2 things
    I looked up and the model I found is a washing machine but you have posted in a dishwasher forum
    which is it just to make sure we are talking about the same thing
    also have you got the pnc number ( look on the model label)
    ryansmcfadyen
    Definitely a dishwasher.
    PNC 91123251800
    #462696
    incomplete model
    there is an L60820 which is a washer
    yours is an FAV60820 which is as you say a dishwasher
    wiring diag does not give a lot of info
    seem to show live and neutral wires as brown and blue but shows the other wires connected to the block as the same colour
    electrically it should not matter which way round the wires go but its nice for safety purpose to have all the switches ( relays) in the live side
    I think you may have to take a guess but as with all modern appliances isolate it from the mains when not in use to reduce risks
