AEG 60870 Error code 30
  • #58928
    Latham63
    Machine comes on briefly then flashes error code 30? Prevous to this it would come on,fill and wash for a few minutes before producing error code.
    This code isnt mentioned in Known Errors??
    #336136
    Seamy
    Re: AEG 60870 Error code 30
    Chek anti flood in base
    #336137
    agree with seamy
    fault 30 if i have correct model as there are 13 variants to this dishwasher
    Water remains
    in base trough
    Leakage at recipient, discharge trough, hose system (e.g., Y-type hose), regeneration dosage
    Inlet valve faulty
    Water inlet too high (faulty flow governor at inlet valve)
    Connecting hose regenerating dosing to discharge trough blocked
    Water inlet channels in regeneration dosing unit blocked
    Screens in the appliance clogged (also check spray arm nozzles for clogging)
    Pressure controller faulty
    Pressure controller hose obstructed, bent or leaking
    Pressure controller wiring is faulty
    Foam production in the appliance (splashed rinsing liquid / leaking dosing unit or con-compatible detergent / rinsing agent used)
    hope this helps
