AEG 60870 problem
  • #28034
    raesene
    Hi all,
    I’d appreciate any advice people could give me on a problem I’ve got with my AEG 60870 sensorlogic dishwasher.
    On running it initially I got an error code 30. Left it overnight and tried to re-run it, but now I’m getting Error code 20 and the water isn’t draining from the machine. There doesn’t appear to be any blockages in the pipes as it’s possible to get the waste pipe to drain manually…
    #216613
    Re: AEG 60870 problem
    Too many versions of this one – please post up the pnc number (the one that starts with 9).
    raesene
    The PNC number is 911 232 542 04
    #216615
    20 is fall in water level not detected after 3 minutes, 30 is flood protection shutting off the inlet valve. You have some sort of problem with the water level control system.
    dna
    Hi this could be a problem with regenation dosage being block(side tank on left hand side of machnine. part number 1118146-107
