AEG 61300 tumbles 1 way all the time
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries AEG 61300 tumbles 1 way all the time
  • #34770
    Seamy
    Got a call to look at an AEG 61300, asked for PNC num’ & its 91400112901.
    Customer says its started doing funny things.
    Says it will start if switched on without door closed.
    I thought they would only pump out in this condition?
    Also when it fills to level it tumbles constantly in anti-clockwise direction.
    Timer perhaps?
    #243953
    Seamy
    Re: AEG 61300 tumbles 1 way all the time
    Timer assy laundry 914001129 £340
    😯 thats why i need to be sure!
    #243954
    Hold up Seamy! This old beast needs your special TLC rather than panicking over what your customer tells you? No way can a Timer be realistically considered or fitted as that would be BER in anyones book! 😉
    I would check the air bell/pressure switch system first. Then heater, then motor…If it all draws a blank, charge for your time and write it off! End of……
    HTH? 8)
