aeg 64840
  • #37981
    LittleMan
    Can any one tell me why this w/m only drains, you select a programe and it will only drain all the time have tested float switch all ok
    Can anyone help
    Manythanks Les
    #257315
    Re: aeg 64840
    Can’t find anything under that number, Les.
    Re: aeg 64840
    Just a thought. Check for a short circuit through a water valve. Sometimes they are in series with the pump as a flood protection.
    Another thing, AEG pumps seem to work even with door open IIRC.
    Mike.
    #257317
    LittleMan
    Re: aeg 64840
    This machine is only 2 months old
    Can anyone tell me about the new small black pressure switch
    thanks
    Les
    #257318
    Re: aeg 64840
    LittleMan
    Re: aeg 64840
    Chris
    can this switch cause the drain pump to stay on if faulty
    Les
    #257320
    Re: aeg 64840
    Looks like level 3 on the conventional p/sw is set for flood protection. Have sent you a large file…….
    Chris,
    #257321
    LittleMan
    Re: aeg 64840
    Thanks chris but this one has the new electronic pressure switch
    Les
